- Nov 29, 2014
- 64
- 24,729
The top speed is set by the spring.
Idle speed is generally set by a limiting screw on the carb itself.
Cable position also akes a difference.
It should be installed so when the throttle cable in clicked into the fast detent the throttle arm is just clear of the choke wire
The throttle cable sets the maximun speed the engine car run at.
The govenor then tries to maintain that speed.
