people,
have a push mower, Troy Bilt, 6.75HP B&S engine, and red push primer button appears OK (pressed it onto my palm, and felt to create pressure), cleaned carb well, Ive cleaned many carbs before, but geez- primer does not suck in any gas. You can feel it and hear it when it sucks in, and it does NOT suck in any primer gas.
I did replace the paper gasket behind the black plastic housing too, just in case, but it was a waste of $2. Still no sucking gas. ideas appreciated.
