Briggs & Stratton 6hp model 122H02-0220-B1
Mower sat unused for about 3 years. When I tried to start it, it wouldn't start despite many pulls of the cord.
I replaced the gas in the tank with fresh gas and tried again, to no avail. After spraying carburetor cleaner into the carb fuel inlet and many cord pulls, it started and ran for a minute or so (probably burning cleaner fluid). The mower then died and would not restart. I replaced the carb, but the problem persists--will not start.
I noticed as I was messing with it, both before and after the carburetor replacement, that the throttle linkage doesn't appear to move the throttle plate inside the carb. (see pix below)
