gfp55
- Mar 13, 2014
- 23
- 860
You posted on another thread that a magnet came off the flywheel right? If its still off so is the balance of the flywheel. The flywheel was balanced when new and without the magnet weight the flywheel is off balance. If you have your tires on your car balanced and one of the weights comes off, your wheel/tire is now out of balance and you car vibrates.
I stand by my statement. The flywheel is out of balance, hence vibration. If you put a different good flywheel on the vibration will be gone. Maybe someone else can help you if you don't think I'm correct. I hope things work out for you.
