I finally got everything running good but the only problem is the engine vibrates when idling If I speed It up a little It goes away.
I took the broken magnet of and put everything back together It was the magnet for the alternator not they ignition coil.
Did you remove the flywheel? Did the magnet come off the inside of the flywheel? Do you have a picture of the magnet?
