Catrancher
- Sep 22, 2021
- 5
Hey bertsmobile1, you're a real jerk.
rear engine riders have a control module for the safety switches. Located under the seat on the right side under the metal or plastic cover. That could be your problem.Having same problem and it's highly intermittent. Eliminated seat switch, replaced clutch/brake switch. Even with the mower in neutral it will sometimes start to go dead when the clutch is released. As soon as the clutch is engaged it runs great. As I said this issue is very intermittent. Are there other switches that could be causing an problem? Switches can be notorious for being intermittent. Can't really make much from the wiring diagram. It's poor to say the least.
I beg to differ on that point. That is a baseless accusation with zero evidence there pal. All written in my best CSI language.Hey bertsmobile1, you're a real jerk.
Welcome to the forum Catrancher.By the way, the link in post #7 no longer works. Duh!!
