jpg98
- Apr 19, 2023
- 6
I'm hoping to buy a ZTR this year, so I've been doing a lot of reading and looking around at different models. One thing I've noticed is the varying air filter systems used on different "grades" of equipment.
These seem to fall into 3 categories:
1. Smaller filters that reside under the engine shroud.
2. Higher profile filters that sit under a shroud extension. See below.
3. Canister-style filters in a housing outside the engine shroud.
I definitely see the need for a good air filtration system given the engine placement on these mowers. My gut feeling is that the #1 filter style is not best suited for long engine life.
How about #2? Is it significantly better? How does it compare to #3?
