Elecronic Ignition Availability?
Briggs and Stratton magnetron conversion kit is part number 394970. Cost is about $25.00. Cheaper than a new coil.
motoman
Is the conversion a true magneto, or an electronic kit triggered by conventional points? Please say more about attaching with RTV.
The conversion kit eliminates the points and condenser from the system. You attach the triggering mechanism to you existing coil. I just cut the wires going to the points and condenser as close to the block as I can, so they don't get caught in anything. No need to take off the flywheel and remove them. Page 6, Sec. 2 of this manual talks about the replaceable module, although I have never had to replace one after it has been installed.
http://dl.dropboxusercontent.com/u/12502267/B&S Service Manuals/01_270962SingleCylinderLHead.pdf
motoman
Sounds like a good conversion.
reynoldston
The magnetron I installed it fit on one of the coil legs and glued in place with RTV.
Steve Johnson
I ended up buying an NOS,USA-made coil/ armature from a seller on the Bay, should be here by Tuesday. About 34 dollars, shipped.
Fish
Yes, much easier... If it is the newer style?
Steve Johnson
I bought the 793281, which Mikel1 recommended, to replace my coil. No need for the separate module, since my engine is from 1968.
Fish
Yeah, almost any shop would have a pile of good coils from all of those pushmowers that got a bent shaft, they would part with those coils for 5$ or so.
Steve Johnson
I am partial to putting on new parts. Its a 46 year old NOS mower, no sense in putting an old part on it, 34 bucks is cheap, to me.
