Ringneck
- Jan 1, 2013
- 23
I'm looking to purchase a new Echo SRM-225 straight shaft trimmer from Home Depot. I plan to use the trimmer for residential purposes. My question is will the trimmer run at all angles? For instance if I turn the trimmer on it's side to edge around sidewalks will the engine continue to run without fail? Also, to all the SRM-225 owners...are you happy with the trimmer and/or would you recommend any other trimmer brand in the same price range other than Echo?
