echo srm-225 wont start/run
lawnguy94
ok, so I have an echo srm-225 that I bought used because I thought I could fix it... (I usually can) it will run and die when I pour some gas into the carburetor opening but that's it. I cleaned the carb out and it still wont run should I try rebuilding it or just buy a whole new carb? thanks and please help!
mechanic mark
Are you using Echo 2-cycle oil mix in gas 92 or 93 octane?
Check this out:http://www.echo-usa.com/getattachment/3599b53e-3e6f-47c6-93f0-0d1bf06825cf/SRM225es1112_121709_1.pdf
Troubleshooting page 28.
Operator Manuals, Safety Manuals, Parts Catalogs, Safety Videos | ECHO USA
exotion
Honestly just buy a new one save your self the trouble
lawnguy94
I'm using echos oil and regular gas in it my other echo runs great with that gas/oil the guy I bought it from said that it sat for over a year with gas in it so I'm sure it's just plugged up beyond just rebuilding the Carb. Wouldn't you think?
Ric
Have you already changed the plug, both the air and gas filter, checked the spark arresting screen?
lawnguy94
I just checked the spark arrester screen and its fine the trimmer looks brand new it just sat for a while and the primer bulb just broke as well so im just gonna get a new carb
Ric
haven't checked the spark arrester I will do that though .thx
Make sure you check Both of those air filters. The Fiber and the plastic vent.
lawnguy94
I have. pulled it 1000 times with the air filter off and still nothing ive checked everything nothing is clogged or dirty. do you have any ideas? I should probably just get a new carb wouldn't you think? thanks for the help
Mikel1
I would replace fuel filter & fuel lines. I would clean ultrasonically and rebuild if needed. Easier to just buy a new carb.
exotion
It really is much easier to simply replace.
