echo srm-225 wont start/run
I was just reading from another owner of the same type trimmer and problem;the problem with his Echo was a gas needle spring.
Just buy the new gaskets for the carb. They are usually cheap. I would do this before I bought a new one only because it is cheap, and if it work then you save a few hundred bucks and if it dont work you only lost maybe 10 bucks.
