lawn mower fanatic
- Jun 8, 2012
- 6,749
As some of you know, I got an Echo PB-770T last summer. It performed flawlessly last fall, but as winter approached it started to not want to turn OFF. At the beginning it was just that it sputtered for a few seconds when you pressed the kill switch and then turned off, but as the weeks progressed it got to the point where when you pressed the off button, the idle speed didn't change at all. I'm guessing it's a cable that got stretched/needs adjusted, but is that something I can adjust on my own? Here's a pic of the blower.
I kind of just ran the gas out of the tank and put it away for the winter last December, so now that spring is here I have the motivation to fix it. I don't really mind this problem, because I can just choke the engine to turn it off, but it would be nice to get my favorite piece of Echo equipment fixed.
Thanks
Thanks
