Eatons 778
Got a Swisher in the shop with the Eatons 778-046 hydros.
Two problems
1) fan is demolished so I need a 106014-000 or 109197-000 clockwise fan that does not appear to be available in OZ
2) the oil is cooked ( no surprise there ) so I need to drain, flush & replace it
Neither the service information nor the parts book show a drain plug
I am assuming that the drains are the two hex plugs on one side of the unit and by virtue of there being 2 one is for the pump section & the other for the motor section .
Before I make a mess any one pulled one down before
Second any oil recommendations ?
I have found mobil 1 20W 50 both recommended and not recommended .
The Eatons manual just says high grade hydraulic oil
The swisher manual says "call the dealer "
Eatons service agent just said ISO 68 hydraulic oil
The original distributor down here has no idea ( & no parts either )
FWIW the mower is a rebranded Swisher Z-Max ZT2560
Bert is this the fan? The Eaton PN includes the pulley (sheave). If so then you can try your Briggs Distributor.
Murray (Simplicity) 1719482SM FAN 6.00OD 10 BLADES​
From Service Manual>
Thanks for heads up on the Murray part
The Eatons I have has the fan bolted on with 4 bolts to a flange which is under the pulley
That looks like a Jacks image with 1" per square so I will measure mine on Friday to see if it will fit
The center hub region looks bigger but I should be able to make it fit
Shearing tomorrow & Thursday so after breakie I will be knackered
