This is a neighbor's mower that it and I need help with. Dixie Chopper 2760HP Silver Eagle with no data sticker on it that I can find. I see where there was a sticker under the seat, but it is gone. Nothing on the right frame either. The Emissions Decal has a date of 2/2012. The 27HP Generac Model is 0050584 Disp. 763.0000 Serial Number 8577387 11259 Customer Item 600388.
Starts fine. At full throttle, within a few minutes it starts to surge and as it warms up will pop thru the exhaust.
If I pull the choke out about 1/4 it runs better.
Compression 145 on left bank 150 on right bank
When running, if I pull either plug wire with it running, it runs better.
Thought it was a lean condition causing it. Saw lots of trash in both tanks. Drained both, cleaned trash out, cleaned trash on check valves on the end of the fuel lines in the tank. Replaced all gas lines from both tanks to tank selector, to pump, to pulse on valve cover, to carb, and to expansion tank. Removed and cleaned carb. Was surprised that there was no trash in the bowl. Still runs the same.
Any suggestions would be appreciated.
