At $1,000, sure sounds like it is a Honda HRC model, which is a commercial-grade product with a 24-month engine warranty.
It is important to understand a warranty usually covers repairs
only when there is a factory defect or failure due to workmanship. Just because "it broke under warranty"
does not mean it will get fixed for free. If the customer allowed the mower to be run low on oil and the engine seized, that is NOT a factory defect, so no warranty would apply. But, if an assembly-line worker forgot to install a connecting rod bolt and the engine failed, then of course, it is a clear factory defect and warranty would certainty cover repairs. The language in most warranty documents leaves the dealer to make the initial decision if it is a defect or not, and if escalated, a final decision is typically made by a district service manager or technical specialist from the manufacturer who has examined details of the specific problem and failed parts.
FYI, here are the current Honda mower warranty terms, effective for all mowers purchased after January 1, 2010:
Residential Use:
* HRR, HRS Models, 36 Months
* HRX Models, 60 Months
* HRC Models, 24 Months
Commercial (for-hire) Rental, Institutional Use:
* HRR, HRS Models, 3 Months
* HRX Models, 3 Months
* HRC Models, 24 Months (engine) 12 Months (all other parts)
Additionally, the HRX has a
Limited Lifetime Warranty on its NeXite/composite mower deck, valid for original, residential-use owners.
Link to full warranty document:
Distributor's Limited Warranty (.PDF document)
