lawn mower fanatic
- Jun 8, 2012
- 321
- 6,749
This morning I adjusted the height of the deck on my Honda HRR216TDA to see how low it would go....it nearly touched the ground. I couldn't even get it out of my garage without it scraping the ground when it becomes the driveway.....it only drops down like a quarter inch!! Just wondering....who would put it as low as can go?!?? If there was the SLIGHTEST bump in the ground the blades would turn it into dirt!! They should make it go higher, instead of going so low! It only goes to 3 in., and my new Honda goes to 4 in.
Attached is a pic of the lowest setting on the mower and the tiny bump that my mower can't get over to get out of the garage when it is on the low setting.
