Hello, I am in need of a belt for my riding mower Yard Machine and the Model# is 13AK608G02 and all I need to know is what size belt I need . Thanks in advance for any help!
Don't go by the belt size. Get the right belt from a dealer. That is a problem I see a lot. A person go's to a auto parts store with a belt size and saves a few dollars and now don't understand why the belt keeps coming off the pulleys.
I agree. You may have problems with an automotive belt. If your belt is still intact, I have had good luck with a local guy that just sells belts, pulleys, and bearings. He can match any belt / application, and is usually cheaper than OEM. It's just another option if you can find someone locally.
Bruce
This is all well and good for you but will it be for this other person? I have found that this local person you are talking about doesn't know all they need to know about belts not saying yours isn't good. Go to the dealer and get the right belt and do the job right the first time.
