Craftsman Garage
- May 2, 2021
- Threads
- 34
- 330
Bought a craftsman dgs6500 with a kohler sv735 vtwin engine for $300. Previous owner replaced the head gaskets and couldn't get it started or something? This was a few months ago before all the snow here in oregon. Got it running...BARELY. Was smoking bad when running (Major disappointment #1). Eventually found out that the carb float needle was messed up and allowed all the gas to pour into the crankcase . While I was at it I cleaned up the carb and she ran much better. I finally get time to look at the deck and the mandrels (3) were junk. Bent up, broken bolts, bearings shot (Major disappointment #2). Bought new mandrels and blades. Put the deck back on and BANG, the deck belt is now a pretzel (Major frustration #3, that deck is everything but easy to unmount, not to mention its WEIGHT). I forget about it for a while. It's winter and I wanna try out my blade. Wasted an hour and only moved a few feet (not machines fault). When I come back to try again the next day the engine starts smoking in key on position. I am furious. Fast forward to when it's NOT 15 degrees outside, I convert the coils to mdi. She runs and drives and I eventually fixed the deck belt issue! Here's where it gets BAD. When I engage the deck, the engine bogs and takes a wh ile to get the mower up to speed. Strange... Bad rings? Sheared flywheel key? Carb needs adjusted? I dunno. I sell it for $1k+ thinking that it's normal??? When I go to start it I will have to crank it for a few secs with choke and then without and then it will start. Anyway, I sell it and that night the buyer texts me that he took the valve cover off and it was running on one cylinder because the pushrods were just laying there and there was water in the oil?! No idea how the water in the brand new oil happened. I changed it a few days before he bought it. I assume the thing with the pushrods is because when the previous owner didn't do some thing correct when he replaced the head gasket, or just plain forgot to put them in. Regardless of all that crap, I'm never buying another kohler courage again, PERIOD.
