Damaged Toro Zero Turn Kohler
smokeless
Well we moved to southern MO, the movers dropped a gun safe on the zero turn and it will not run. I believe its a fuel issue. A hose was pull off but for the life of me I cannot locate where it connects, and the picture is too large to upload. The fuel delivery system seems damaged, especially what seems a fuel pump, but I just learned its vacumn controlled, is that correct? Thanks for any help.
A vacumn fuel pump has 3 connections one to the crankcase , one to the fuel supply and the other goes to the carb,
