Damaged Toro Zero Turn Kohler
smokeless
Well we moved to southern MO, the movers dropped a gun safe on the zero turn and it will not run. I believe its a fuel issue. A hose was pull off but for the life of me I cannot locate where it connects, and the picture is too large to upload. The fuel delivery system seems damaged, especially what seems a fuel pump, but I just learned its vacumn controlled, is that correct? Thanks for any help.
Bertrrr
A vacumn fuel pump has 3 connections one to the crankcase , one to the fuel supply and the other goes to the carb,
Goes to show them fire arms are dangerous even in their boxes
packardv8
And this is in the Troy-Bilt forum why?
