Cuts off
navydad2022
my victory was short lived,got my snapper going after replacing neg and positive cables.Now when l press the brake / clutch paddle and let go to mow and my engine shuts down.if l press the paddle back it stays on.
Pull the small black wire off the ignition coil. Should run the tank dry "if" the coil is good. This will bypass all other safety switches, JUST FOR TESTING purposes.
Stop & think
Why are those witches there ?
The seat switch is there to prevent you doing stupid things like getting off with the blades running and shoving you hand into the discharge chute to clear a blockage plus to prevent it running away driverless should you fall off
However the engine has to be able to run when you get off to move things or open a gate .
SO the seat switch works in combination with both the blade switch & the parking brake switch .
On top of this some of the switches are open then close when the plunger is down or visa versa so it is easy to get the wrong switch .
Stop & think
Thank you for your expert advice 🙏,it just caught me for a loop as to what was happening
