Hello everyone,
I am a French tenant in a house, and my landlord has an Ecloz brand robotic lawnmower. I have never dared to use it for fear of mishandling it, as I am not at all skilled with new technologies, so I use a gasoline lawnmower instead.
While doing some gardening, I accidentally cut a wire that was buried underground, (see the turquoise wire inside the red circle, on the photo attached).
There are similar wires near the charging base of the robotic lawnmower, so I assume it is either an electrical wire or a guide wire.
Here are my two questions: Is there a risk of electrocution or any other danger by touching this wire?
Will the robotic lawnmower be dysfunctional because I cut the wire?
Thank you very much for your help.
I will provide more information if needed.
