They code out as A 36 & 3/8" ( aust ) or A 38 & 3/8 US..
and 954-3084 appears to be the right part according to my parts list as well.
However for the belt to be the correct size according to the book all 3 pulleys need to be the correct size according to the book
Now if you are 100% sure that the PTO is set up properly & working properly then just grab some shorter belts
If you still have the old ones measure the outside of the belt for the Aust belt size.
Kevlar belts do not stretch and pollyester ones actually get shorter .
Otherwise get 40" of 1/2 rope and run it around the pulleys, PTO off , mark where the 2 ends meet then add 1" to it.
Always a problem with used mowers, you can not trust anything on there is std.
The engine pulley is a variable one consisting of 3 Sides with spacers between to change the pulley size and thus the gearing ratio.
So check that there are no spacers between the sides on the engine shaft which would have the effect of making the pulley a smaller diameter.
