greynold99
Hi all,
I finally got around to ordering some new rear tires for my 17 yr. old Cub Cadet 2135 - original size 20 X 9 - 8.
On looking over various tire sites, I soon realized that the 9-8 size was no longer available and only 20 X 8 - 8 or 20 X 10 - 8 were available... So, I called Cub Cadet Support and they indicated the smaller 8-8 would not fit but the 10-8 would fit Ok.
I have chains on the original 9-8 tires and it looks like there should be enough additional length and width to fit the larger 10-8 tire... But before I actually need to change the tires, does anyone know if that is correct or will I need to get new chains specifically for the size of tire?
Alternatively, are there ways to expand the length of the original chains to accomodate the slightly larger width?
Thank you,
greynold99
Thank you,
greynold99
Read more: Cub Cadet 2135 Rear Tires size change-Will tire chains original size tires fit? - DoItYourself.com Community Forums
