Ok so it looks like the Anti Dieseling Solonoid is working, I turn the key on with the solonoid in my hand and the solonoid closes, with the key off the solonoid opens to resrict fuel into the carb, this is the correct way it should work from what I can understand.
I thouroughly cleaned the carb and by bi-passed the fuel filter and still have the same problem, mower will start run for a few minutes and die, the only way to restart is to hold my hand over the air intake.
I don't understand why.... I know with the experience I have that the problem is fuel related but i have done all the steps... starting to get frustrated!!!! :confused2:
