craftsman t1500 ground drive belt help
mark60
craftsman t1500 247273740 came to me with a broken wheel drive belt i found the belts but there is no diagram under the tractor. i can not find the routing for the belt. you t search did not find any thing that looked like this machine. any help would be appreciated.
This maybe the closest you will find a diagram from MTD/SBD in some cases. 1752397053277.png
But you can go find a similar Troybilt, Cub Cadet, Etc with the same pedal configuration as your mower at a box store and have a look under he mower., and doesn't have to be exact same model, because MTD uses the same belt routing on all of the variabe speed gear shift style mowers.
