Born2Mow
Try a a battery disconnect, as found on Amazon and other sources.
Your battery is being sucked dead by an electrical fault. But this can ONLY occur if you leave the battery connected in the circuit. This simple device completely disconnects the battery from whatever your electrical fault is.
Now you may ALSO have a blown regulator which is only sending 1/2 charge or No charge to the battery. Or, you might also have a low-level electrical load (like lights or ignition ON all the time) that is pulling the battery down between mowing sessions. That needs to be checked out.
When you use a battery disconnect, your battery ONLY gets charged... NEVER discharged. They have also ended winter trickle charging for me.
