nine51
- May 30, 2011
- 0
- 5
Hey there. I just bought a Craftsman LT2000 Lawn Tractor about three weeks ago when Sears had them on sale. It is my first lawn tractor, but I have used many of them in my teens and 20's mowing lawns in the 60's and early 70's. We had several Bolens, Wheel Horse, Simplicity and Cub Cadet tractors over those years and I put many hours on all of them. Mowers sure have changed since then. Too many safety features, but I guess they save a few fingers and toes.
My new mower is the 2011 LT2000, 19.5 HP Briggs, Gold series engine, 42" cut, foot pedal speed control. I think it's actually built by MTD for Sears. I've mowed with it four times since I got it and it makes quick work of the yard. The foot controlled speed feature is great for creeping around bushes and shrubs. I installed a digital hour meter that I bought on Amazon.com. It has a tachometer feature that shows RPM when the engine is running. It switches to the hour meter when the engine is off. I also found the wiring for the anti-reverse mow safety switch and disconnected that, so now it can mow in reverse. No kids or dogs to run over here, so I guess I'm pretty safe.
I installed a front bumper kit, mostly so there is a place to grab it to move the front end over to get it out of the way of the car when it's parked in the garage. Also, the front hood/engine cover is a little fragile, so that may help keep that in one piece. Looks good too.
I've read lots of reviews for mowers in this price range. Many different opinions about reliability. It is very similar to a Cub Cadet that Home Depot sells. Different engine, but it is also made by MTD. Lots more $$. I guess this machine will not be used that hard and will probably be pampered like my cars and other rolling stock so if it doesn't have any overt design flaws it should last for a few years. Seems like the one good thing you can do for most of the lawn and garden equipment is either use non-ethanol gas, or use a stabilizer like the blue Stabil. That may help keep the engine running longer without problems. It's worked for my snowblowers and push mowers. I also plan to change to Mobil 1 synthetic oil after the first change at the recommended 5 hours. That also has worked well for my other small engines. I just sold an old Ahrens snowblower that I bought new in 1978 and always ran Mobil 1 synthetic oil in it and used Stabil in the gas. It still started on the first pull and always ran good.
I joined this forum so if I do have any problems, maybe there will be someone here with an answer, before I haul this thing off to the shop. I also like to mess with my machines to see if there are things I can do to make them work better.
