- Nov 29, 2014
- 64
- 24,647
Not sure up there.
The USA has a bad habit of measuring things differently to the rest of the planet .
Down hee the clips are specified by the size ( diameter ) of the shaft they go on .
SO if the shaft is 1/2" then you use a 1/2" clip which will measure .040" under that because that is the depth of a std groove.
