Craftsman Gas Leaf Blower...HELP PLEASE!
Fish
OEM Parts
It looks like one of @ 10 models on this lookup...
sillyboy
OEM Parts
Also the fuel line is very thin. What size is this. I need to buy more. This leaf blower does not have a primer bulb.
OK Thank You!
Most of the poulan stuff uses .080 ID, .140 OD for the line with the fuel filter and 3/32 ID 3/16 OD for the other lines
sillyboy
Thank You ILENGINE...
midnite rider
midnite rider
There is normally a 2 x 3 inch sticker some place on the housing. I have seen them fade and not be readable, I have also seen cases where the sticker was put in the box with the blower, and was never installed, which means it is gone. model number should start with a 358.
The instructions, model# and serial# are located on a decal on the top of the air cleaner cover underneath the top handle.
sillyboy
Nn wonder I couldn't find it, the cover is missing. I need to make a phone call...:ashamed:
Thanks to everyone for the help.
SB
