Craftsman Gas Leaf Blower...HELP PLEASE!
sillyboy
Hi,
My metal detecting buddy gave me a Craftsman Gas Leaf Blower. On the side Cover:
Sears Best/Craftsman
Power Blower/Vac
Gas Operated
32cc 360 CFM 170 MPH
I can't find a serial no. or a model no. on this equipment. Is it hidden? I got no. off the carb. WT141A = Walbro
Can I get a manual for this?
Seems that it will not stay running after starting. It ran last year, I was told.
Any info would be of a great help.
Thanks
Fish
Is there a sticker on the air filter box or cover? It is an old Poulan, look for any part numbers you can see, we may be able to run it backwards and get a model.
There is normally a 2 x 3 inch sticker some place on the housing. I have seen them fade and not be readable, I have also seen cases where the sticker was put in the box with the blower, and was never installed, which means it is gone. model number should start with a 358.
sillyboy
I'll take it apart some more, and return here.
Thanks
sillyboy
Anyone know about what year this was built?
Thanks...
Fish
1990s, or so...
Fish
Look on the throttle cable, should have a number on it!!
sillyboy
Hello,
I found this no. on the throttle cable housing: 530-037492 B
Thanks
