Craftsman DGS 6500 - needs carburetor
Same with limiter caps on handheld equipment, low and high adjustments. Occasionally these caps need to be removed to get the air/fuel mixture just right as the equipment ages.
The stuff they do sometimes to prevent anybody from adjusting a carb is crazy. From the epoxy filled adjustment screw area to the Stihl I ran into last year that needed adjusted and the caps were secured with blind roll pins.
If it is the ones I thinking of they are a royal pain to even get them to the release point. And the screws have plastic around them that can seize so can't adjust them even with the caps completely removed. I had to replace a carb last year because I couldn't even get the screws out so I could replace them. The new carb was easily adjusted with the hex bit thru the center hole.
That's the one. Seem to remember this one was on a MS361 I think.
more likely a MS251 or MS261 that has this metal cap that requires a 3mm extraction tool. The MS361 has a plastic one; unless, it has one of the latest carbs.
And I see the problem that I had the darn plastic insert didn't come out when I pulled the cap.
007
Where do you get the carb rebuild kits?
Where to get rebuild kit depends on the OEM and carb. Stihl with a controlling interest in Zama has blocked most of the kits. Even their dealers can't get rebuild kits. But I can be resourceful enough to find them a lot of the time but not always.
So what carburetor you looking for a kit for?
