- May 6, 2010
- 12,047
The stuff they do sometimes to prevent anybody from adjusting a carb is crazy. From the epoxy filled adjustment screw area to the Stihl I ran into last year that needed adjusted and the caps were secured with blind roll pins.Same with limiter caps on handheld equipment, low and high adjustments. Occasionally these caps need to be removed to get the air/fuel mixture just right as the equipment ages.
