Hello I had problems with my deck belt as well, the problem I had was every belt I tried was to tight, and would engage when try starting the engine. So what I did was end up pulling the whole deck out checked all the pulleys, and ordering a original craftsman belt, not and OEM belt. The black belts were the OEM, the craftsman original belts were like a brownish color.Goodday to all. New to the site so I hope someone can give some help. I have a Craftsman 944.601171 17.5 hp, 42 in deck. Anything I can find for the deck belt calls for belt pt# 144959 which is 95.5x 1/2. I have checked the routing 50 times if I did it once, this according to the diagram on the deck. VERY simple routing. There is no possible way that the belt will work as it falls off the engine pulley when it is engaged. I am hoping someone else has run across this problem and can give me some hope of ever getting the right belt. I have tried all kinds of length of belts . A 92x1/2 comes the closest. Thanks in advance.
check and make sure the pulleys on your spindles are the right size, if they are too small, it will cause the belt to be too longGoodday to all. New to the site so I hope someone can give some help. I have a Craftsman 944.601171 17.5 hp, 42 in deck. Anything I can find for the deck belt calls for belt pt# 144959 which is 95.5x 1/2. I have checked the routing 50 times if I did it once, this according to the diagram on the deck. VERY simple routing. There is no possible way that the belt will work as it falls off the engine pulley when it is engaged. I am hoping someone else has run across this problem and can give me some hope of ever getting the right belt. I have tried all kinds of length of belts . A 92x1/2 comes the closest. Thanks in advance.
Clutching belts must be wrapped otherwise they can not slip.Hello I had problems with my deck belt as well, the problem I had was every belt I tried was to tight, and would engage when try starting the engine. So what I did was end up pulling the whole deck out checked all the pulleys, and ordering a original craftsman belt, not and OEM belt. The black belts were the OEM, the craftsman original belts were like a brownish color.
