Need2learn
- Apr 27, 2015
- 7
- 32
Update I was able to get it right, after trying like 3 belts from amazon they were ALL TOO TIGHT, I found a original Sears Belt and it was like 1 1/2 longer, I put that belt and it works just fine.. Stay away from Amazon Cheap Chinese belts they will NOT FIT.
I even ordered a blade cable and THAT WAS TOO SHORT... I had to reroute into to get it to work... the black belts you get are OEM junk,,, make sure you get the brown original sears belts.
