Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Ok, mowed earlier and the cut is a little better with a stripe; just not a very visible well defined stripe. I think it will look a little better after a few more cuts. New problem I ran into while mowing however was the mower started to sputter like it was going to die, so I would stop and let it rev back up and it would mow for a minute or two then start cutting out again. Turned the pto off and headed down the street back to my house and it was still doing it, so I'm going to rule out pto related. My first guess is the fuel filter, so gonna look for a new one tomorrow. Hopefully thats all it is.
Also, another question for you guys. Mower was slightly low on hydraulic oil and manual calls for 20w30. All I had was 15w40 so I added just a little bit to top it off. Will tha be alright or do I need to get the right stuff and change it out?
Most but not all Scag ZTRs use 20W-50 engine oil in the hydraulic systems. 15W-40 is OK for a small amount.
Check the operators manual for your specific machine.
Mad Mackie in CT:laughing::biggrin::smile:
