Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Hi Sonders,
I just went out and looked at my machine and there are no flat spots on the long rods, the flats are on the short rod that adjusts for height.
The left forward and right forward bellcranks are connected together by a tube that is under the machine. The right hand belcrank has the foot pedal mounted on it. The suspension chains are connected to these bellcranks and to the forward deck lift points. The long rods attach to these bellcranks and go back to the rear bellcranks which are independent from each other. The rear bellcranks have the rear suspension chains attached to them and connect to the rear deck lift points. The rear bellcranks are the only adjustment point. If the front of your deck is too high, then you need to adjust the long rods to lift the rear of the deck. After the deck is leveled, then you can adjust the short rod to match the blade height to the indexing on the height adjusting matrix. After you are happy with your adjustments, I recommend that you tighten both of the nuts on the rods against the swivel. This will prevent the rods from turning from vibration and letting the deck get out of adjustment again!!!!
I've got four machines in my shop each with a different deck!!!
Mad Mackie in CT
Mad Mackie in CT
