People,
MTD mower turned over a bunch of time, weakly, and never started. So I cleaned off the corrosion from the positive battery cable and noticed the terminal on that red cable has ben reduced by corrosion over 26 years to about 1/2 the surface it originally had. Does this make a big difference?
It is made of yellow bronze (brass??). Need I replace with same type? Or can I use aluminum? Have yous done this before? Do I just pry apart the clamped/crimped fasterers and recrimp?
Thanks, people.
Thanks, people.
