Corroded ring terminal, battery cable
rigoletto
People,
MTD mower turned over a bunch of time, weakly, and never started. So I cleaned off the corrosion from the positive battery cable and noticed the terminal on that red cable has ben reduced by corrosion over 26 years to about 1/2 the surface it originally had. Does this make a big difference?
It is made of yellow bronze (brass??). Need I replace with same type? Or can I use aluminum? Have yous done this before? Do I just pry apart the clamped/crimped fasterers and recrimp?
Thanks, people.
If it was me and had that much corrosion, I would be replacing the entire cable. More that likely the cable insides are also corroded. I never use aluminum connectors on cable that size, always use copper or brass. I also never use crimp connectors on battery cables. I use solder connectors. I also use 8 gauge cable.
Always put on new terminals and haven;t tried reusing already been crimp terminals.
And with being a MTD the battery cable is probably 8 gauge copper clad aluminum which should be upgraded to 6 gauge all copper cable.
Wow, good to know, people. Maybe thats why the mower wont start. Can anyone find such a cable on say, Amazon? Other? Thanks.
Tractor Supply sells premade cables in different lengths, if you have one nearby
Or any decent shop should have wire, cable lugs, and crimpers to make any length cable.
I have a special crimping tool to put the cable end on. It is made where you put the end in kinda of a cradle and you smack the crimper with a hammer. really tight crimp.
