Yesterday I shut off the fuel and let it completely run out (took like 60 seconds at least idling before it finally died - maybe the shutoff isn't sealing perfectly?) This morning I turned on the fuel and immediately tried to start it ..still the same thing, fires briefly and stalls...over and over again firing a little bit longer each time before dying. No real noticeable smoke or smell despite being in my garage. I ordered a new Chinese carb from the states so I guess that's my next attempt to fix it. I've been driving carbureted cars for 22 years since I was 16 and this behaviour seems odd to me, but obviously a single cylinder Briggs with manual choke is not the same as a V8 with a 4 barrel with electric choke.
I accidentally stopped the video I was recording at 1 second...so I'll just post the one from yesterday. The issue is much worse the longer it sits...after the first few failed starts ...it seems to prefer around 3/4 throttle but it will start at any throttle position except choke once it's get a tiny bit of heat into it. My original thought was not enough choke closing but that doesn't seem to be the case.
New item · Album by Mike Kennedy
photos.app.goo.gl
