Well she seems to be fixed. I assumed you were probably right about a valve issue... unfortunately I don't have a before compression test result. Last night I pulled the plug and sprayed a bunch of cleaner on and in behind the valves the best I could, spun it over a few times and sprayed more cleaner...let it sit until tonight. We sprayed one last dose of combustion chamber cleaner in and then some oil and trans fluid mix, then spun it enough to get rid of the excess... did a compression test...about 151psi...I didn't think these engines even made that much compression? Put the new plug in and with a ton of smoke it reluctantly fired up and stayed running.....let it clear out and adjusted the main jet screw until it ran the smoothest and mowed some grass with it. So far it's running perfectly. I'll see how it is on a cold start since that's where the issue originally started. Thanks for the advice.
