Outdoor Environments
I have been told that you can spray a non-stick cooking spray on the under side of mower deck coating it all over and it will prevent grass from sticking to the under side of deck. But they say you have to spray it on when the deck is dry before any mowing. I have not tried this so do not know if it actually works. I doubt it will prevent the grass from clumping up and falling onto lawn however. I live in the upper corner of SC and we had one of the rainiest summer in history with over 50+ inches so you can imagine how the fast the grass grew. On some properties we would cut the grass and let it fall and lay for a bit to dry out some while we did other chores on the property such as prune, weedeat,etc; then go back over it to vacum with our Walkers. Takes a little extra time but sure beats raking.
