I have tried both mulching and bagging and the grass keeps building on the under side of the deck. It gets bad enough that it will fall off the deck and about stall out the mower (grass falls from under side of deck and hits the blades). At times, it gets bad enough that I have to lift the deck and let the grass fall out before I can continue (while mulching). When bagging, it happens often and I end up leaving clumps of grass (not bagged) on the ground throughout the lawn.
I have not tried changing blades as my local dealer tells me I am using the correct blades. This will happen at times when the grass is dry and its 80 outside and happens more often with due on the ground and its 65. I mow twice a week so the grass is not too tall (4 days att he most between mowings).
Any help would be appreciated. Pretty irritating to dump $9k and still have issues.
Tharin
Tharin
lThanks for the replies all. A couple clarifications---It was mentioned in a couple posts to not cut too much grass at a time. I don't think that I am. As I mentioned, I mow twice a week (the most time between mowings is 4 days). I do live in the pacific northwest (60 miles west of Seattle WA). That said, we have had one of our driest/warmest on record. As for deck heighth, I am set pretty high. I only have one notch to go higher. I don't think speed is an issue either as I am going pretty slow. Blades00definately sounds like that could be my issue. I will change them and see what happens. Tharin
Tharin
Are we talking about the Hustler Fastrak you have listed just for clarification, and what size deck?
Ya know, it does seem like I have read other comments in threads by Hustler owners that the FasTrak deck was prone to "clogging"(don't know whether it's deck-size oriented or whether they have exactly the same deck style as the FasTrak Super Duty, which I've not read any reports of that problem).
I was wondering the same thing, seems like I've read on some other comments forums about people having problems also, that's why I asked for clarification, and what size deck he was using and I also would like to know how old a unit it is. Some of the older models were only running in and around 15000 FPM blade tip speed. The new ones are 18 to 18600 Fpm BTS and shouldn't have problems with clogging up.
It has a 48" deck. I currently have the bagging system on it.
Tharin
Decks are IDENTICAL as far as fabrication. Only difference is the pulleys on the SD are metal and SD has high lift blades stock.
Tharin
....I'm having problems posting pics in my album as well...guess I don't have the forum completely figured out lolSooooo.....maybe the OP needs to try some OEM hi-lift blades, right?
P.S.
I'm gonna try to attach some pics of my Gravely deck "before installing the mulch kit" and "after installing the mulch kit" so the OP can compare to what the "mulch kit" installed on his ZTR looks like in comparison(design-wise). If I can just get the attachments to cooperate:0) BTW, you can see in the pictures that this kit completely encloses each blade with a baffle that extends down as for as the outside edge of the deck and is constructed of the same 7gauge steel. It does a FANTASTIC job mulching!!!
B4:View attachment 17410View attachment 17411View attachment 17412
After:View attachment 17413View attachment 17414View attachment 17415View attachment 17416View attachment 17417
I apparently cannot remember user lawn mower fanatic's instructions on inserting pictures as it is a MESS and I can't even get the final pics of "After" to attach(and editing my post doesn't seem to help). Don't know how the "B4" pics also got attached as "Thumbnails". I guess me using Windows 7 as a virtual machine inside my iMac may contribute to my difficulties. Maybe since user lmf has administrative rights if he happens upon my post in this thread he can get my attached photos(B4=3597-3600) and (After=3601-3608) straightened out in this post(I'll keep trying but I really need to get outside and "mow my lawn:0)
I give up:0(
I ended up "losing" the first "B4" pic by trying to delete the attachment(#attachment#17409, photo#DSC03597). The "insert image" screen just seems to show the "top 8 pics" and has a "scroll up"....but no "scroll down" so I cannot get to pics DSC3606-3608(final Afters)...OR to the "re-inserted" pic#3597(first B4).........HELP admins!!!!!:0)
Look here: http://www.lawnmowerforum.com/site-discussion/31-how-create-photo-galleries-upload-photos.html
And user djdicetn's attachments were fixed. :smile:
I'm confused? My deck doesn't clog. High lift blades for mulching? I have no clue....
I bought a second set of blades -high lift - fusion blades. But I haven't even tried them yet. Next spring probably. My deck looks clean underneath but I never mow wet grass. Pacific NW you probably need an umbrella and snorkle to mow. :smile:
Again my deck isn't a mulch deck and my deck with regular lift blades doesn't clog. I mow at 2/3 throttle tops. 1/2 throttle is fine. Just depends on what time of year here grass is thinner in the late summer than spring , spring grass is thicker and requires more throttle.
I don't have a bagger either....
Really......I've never heard of anyone "mowing" at 1/2 or 2/3 throttle and I thought this was not recommended in regard to cut quality(and possibly adverse effect on the trannies). I'm no expert, but have read this advice on these forums. Of course....if it's working for you and your Hustler owner's manual doesn't warn against it I "guess" it's OK.
You engage your blades at about 3/4 throttle then back it down a little.....my dealer told me he mows at half throttle. My blades are spinning plenty fast enough. Full throttle is ridiculous on my machine.
It is ok. The only issue is blade engagement and the blade clutch spinning fast enough when you engage blades.
You also need to throttle down to disengage them. Trannies , not so much. They are always engaged w/hydraulic fluid. I drive my machine into the out building at idle. Never worried before. You are confusing the clutch for the blades w/ tranny operation, I hope.
I'll take my lawns cut anyday , everyday. Full throttle is just wasting gas for me. Maybe If I were mowing a hay field. :smile:
Thanks, lmf...you got er dun!!! I think my problem may have been related to me not "naming the jpg files" like you mentioned in your message to me. Anyhow, user PVhlll will benefit from that link you gave(I was in a hurry to get outside and mow the yard, got frustrated and forgot about those instructions). Hopefully, there are a couple of users who have reported some problems with mulch kits and I can direct them to the pictures of the Gravely kit which I consider a "model" for a good kit(heavy gauge, fully encloses the blades and extends to the bottom of the deck edge). If their kit isn't similar in design(and just consists of a discharge chute cover) most likely they cannot expect the same results that I am getting. Again....thanks for taking care of the mess I made with my pics!!!!!
I have been told that you can spray a non-stick cooking spray on the under side of mower deck coating it all over and it will prevent grass from sticking to the under side of deck. But they say you have to spray it on when the deck is dry before any mowing. I have not tried this so do not know if it actually works. I doubt it will prevent the grass from clumping up and falling onto lawn however. I live in the upper corner of SC and we had one of the rainiest summer in history with over 50+ inches so you can imagine how the fast the grass grew. On some properties we would cut the grass and let it fall and lay for a bit to dry out some while we did other chores on the property such as prune, weedeat,etc; then go back over it to vacum with our Walkers. Takes a little extra time but sure beats raking.
