gamma_ray
- May 14, 2015
- 45
What is it for then?No. That not what are designed to do.
Definitely on dumping the oil. Maybe 2 or 3 times to get all the fuel out.So I bought a new needle and float and installed them. I have not tested them to see if they are functioning property.
I did cut grass when the needle tip was broken off, so I assume the needle was not working at all at that time. The mower ran properly and I shut off the fuel as soon as I was done.
Do I need to change the oil because I ran the mower without a properly working float?, or will it be ok, because the needle does most of the work when the engine is off?
