I have an issue with my Rato 670cc engine charging my battery. Its a new battery, but will not hold a charge. At full throttle, when I test the wire plug from the voltage regulator, it shows 13 to 14 volts. When I test the wire plug to the battery it shows 12.1 volts. When I connect the two plug wires together it still only reads 12.1 volts at the battery. Any suggestions as to why the voltage regulator is not sensing the battery voltage or something else I should be checking? Is it possible that the voltage regulator is still defective? Any advice is appreciated, Thanks.
