Charging System Problem.
jmdls
I have an issue with my Rato 670cc engine charging my battery. Its a new battery, but will not hold a charge. At full throttle, when I test the wire plug from the voltage regulator, it shows 13 to 14 volts. When I test the wire plug to the battery it shows 12.1 volts. When I connect the two plug wires together it still only reads 12.1 volts at the battery. Any suggestions as to why the voltage regulator is not sensing the battery voltage or something else I should be checking? Is it possible that the voltage regulator is still defective? Any advice is appreciated, Thanks.
I am thinking could be an issue where the system isn't grounding properly or there is an issue with the wire from the battery to the regulator plug. Basically will carry voltage but not carry amps.
With all the wires connected you can either connect a temporary wire from the +battery to the regulator output and see if it starts charging. That would rule out a bad regulator to battery wire, and can also take that wire from the -battery to the case of the regulator and see if it starts charging. If it charges then you have a ground problem. The same test can be done with the volt meter. meter should read 0 or close to it in both test.
I am assuming that the 13-14 volts is wire going to the battery and not 13-14 AC output from the charge stator.
jmdls
Thanks Ilengine for the response. I'll try your recommendations. I've been reading some of your replies to folks having similar charging issues and you have provided me valuable information on testing the charging system. You mentioned in one of your replies about an ammeter in the circuit that could be causing the problem. I have and ammeter that lights up when I turn on the headlights, but it's not registering anything. Could this ammeter possibly be causing my problem, or could it not be registering due to the problem with the charging issue? I'll follow up and post my results after I run the tests you recommended. Thanks.
jmdls
And yes, the 13-14 dc volts I am reading is from the B+ wire coming out of the voltage regulator. Thanks.
jmdls
And yes, the 13-14 volts I am reading is fron the B+ wire coming out of the voltage regulator.
I reckon a wiring schematic might helpful....
Thanks StarTech!
jmdls
I ran a test wire from the B+ terminal of the voltage regulator to the positive post of the battery. On the multimeter, I was reading 13.5 volts. I assume the regulator is working to be getting that reading, when I was just getting 12.4 to 12.5 before. I want to suspect my problem is in the wiring from the regulator to the battery, except this happens when I power up additional loads to the system. On my led lights and panel lights, when on, the voltage reads at around 12.5 volts dc consistent. I have a 12 volt dc cooling fan for the hydraulics, that when switched on, it brings the voltage down to 11.8 volts dc. I run the fan consistently clear up to powering down the engine. I am wondering if that's where my problem could be, for when I shut down, the battery is at 11.8 volts. Your thoughts? Could this fan be the culprit drawing down that much power out of the battery, when I would think it would use the same amount of voltage as when the the lights are being used.
Any suggestions are appreciated, Thanks!
Got to ask. What engine speed it all this happening? Are you one of those that idle down and wonder why your battery is dead all the time? Please explain.
The question becomes what it the amp output of the charging system, and what is the watts/amp draw of running the lights and the cooling fan.
IL according to the wiring diagram for the Rato 670 the stator produces under 5 amps as it is fused at 5 amps. And battery is fused at 10 amps. So basically it is design mainly to recharge the battery and keep the fuel solenoid powered. Not much extra for anything else so it sounds like the OP is over taxing the system and the battery is having to provide the extra current that the alternator can't; otherwords, it cant keep up with the current draw and the battery starts draining. With the stator being fused at 5 amps I would say the stator is probably a 3 amp version.
I would be testing the amp draw to see if amp draw is too much. If it is then basically the only solution is either install a higher amp alternator, which I don't think is available for the Rato, or reduce the electrical loads.
