Ok, I have replaced the battery, stator and flywheel this week and everything went well. Engine fired right up and the volt meter indicated it was charging. I took the mower out and was driving to the front yard and the engine died. It was at full throttle and top speed, blades not engaged. I checked and the fuse for the charging system was blown and very hot. I replaced the fuse and she started right up. I was able to cut some of he lawn for about 20 minutes and then it blew again. I did notice that the volt meter was pegged to the right, past the 10. I checked the current at the batteries, full throttle and it showed 13.6. There was some chewed wires, but I wrapped then in electrical tape. Not sure where to go from here?
