GasSniffer
- Jul 17, 2013
- Threads
- 31
- 237
I did a drain and fill on my Toro 75734 by sucking the oil out when the hydros were hot at about 80 hours. Got about 0.75 qt out of each one and filled an old pickle jar with it. The oil sat in that clean jar for months. I just drained the jar the other day when I was turning in old oil and there was about an 1/8 inch of grey sludge at the bottom of the jar. I was pretty surprised at that. I have about 120 hours now and I will probably do another drain and fill at the end of this season. Unfortunately these are 'factory sealed' units with no drain plugs or external filters. The only was to do the service without removing them is by sucking the oil out through the fill cap. I put Valvoline 20w50 full synthetic in it.
