Changed fuel filter, not starting - Briggs 31000 Series (Dixon SZTR30)
RZ3016
  • / Changed fuel filter, not starting - Briggs 31000 Series (Dixon SZTR30)
Thanks - both valves and rods are moving now and to spec. Will try again when battery is hot.
RZ3016
Yearly maintenance + incorrect assembly of valve system = closed intake valve/no start
Running as usual. As I expected no less, you all were super helpful. Thanks for being patient with my multiple posts as well sharing information I certainly will know for the future.
Until next time,
Gary
Luffydog
The white smoke might have been from a backfire causing it to bend or throw the out sometimes the rocker arm
Bolts back causing to get loose to where the rods have no chance to operate like they should. Keep us posted
Glad you got it going....... I been to Gonzales many times when I lived in Grosse Tete La.
