couchmusician
- Aug 22, 2020
- Threads
- 1
- 7
The outer blades are difficult to rotate manually as opposed to the center blade that can be spun very easily manually. Is this normal?
Yes....some mowers do that, some spindle pulleys have more belt going further around them than others.The outer blades are difficult to rotate manually as opposed to the center blade that can be spun very easily manually. Is this normal?
The 5 things that make a good cut: 1st - sharp blades, 2nd - bottom of deck not packed full of grass, 3rd - level deck, 4th - engine RPM is to spec, 5th - not cutting too much/tall of grass at one time!Thanks, that makes sense.My reason for inquiring is because when mowing thru tall heavy grass the center blade does not cut as clean as the outer blades which requires a second pass thru the same area. Thoughts anyone?
If you do ALL 5 things I posted in my last post, you'll be mowing better than before.....you can't be focused on just one thing!Your interpretation of tall/heavy grass is probably different than mine.Besides, the outer blades handle it quiet well, so the gentleman who responded first had the most logical explanation. I'm going with that. I'm going to explore for a way to increase the friction on that particular pulley, such as a tape that has a coarse surface. Just a thought. I really like this mower and have been trying to contact "cub cadet" by phone and email but to no avail. Numerous phone calls and I finally found an email contact address [3 weeks ago] and sent my inquiry but have heard nothing. Has anyone else had this contacting issue?
I wouldn't remove the deck to clean the bottom of the deck but, you can do it that way. Have you checked your rpm's?All 5 things are in order. This is a brand new mower, only 12 hours. Purchased last month. I remove the mower after each job and thoroughly clean the underside.
